brothernature Posted April 7, 2014 Share Posted April 7, 2014 I pulled up the carpet last week with plans to replace it and found some rust. Today I started grinding it away and ended up with a few pinhole sized holes on the drivers side, one dime size and another quarter size on the passenger side. I filled them up with JB weld in order to sand it down and paint tomorrow. Is this okay? I'm thinking eventually I'll have the comanche painted and get some body work done if I can find a good price, so is this a good temporary solution? Link to comment Share on other sites More sharing options...
Dando Posted April 7, 2014 Share Posted April 7, 2014 I would think it would work fine but I would be very cautious and try to seal the area best as I could. I would worry that it will continue to rust. If they truly are small pinholes why not grind them to completely bare metal and have a friend or a body shop take a few seconds and fill the pinholes with weld? Link to comment Share on other sites More sharing options...
ckjeep Posted April 7, 2014 Share Posted April 7, 2014 if thats all the rust you have you are one lucky person!! Link to comment Share on other sites More sharing options...
wvzj Posted April 7, 2014 Share Posted April 7, 2014 Maybe paint it with some por-15 and use some seam sealer Link to comment Share on other sites More sharing options...
92tanMJ Posted April 7, 2014 Share Posted April 7, 2014 Bedliner both sides? :dunno: Link to comment Share on other sites More sharing options...
