'94ZJ 4.0. Can anybody explain to me why it takes seven bolts to hold a PS pump on? What was wrong with two? One for a pivot and one to clamp the adjustment.  :dunno:  :hmm:  :???:
Cause they like to throw a wrench into everything simple and make things overly complex?
its some comp nerd that figures the oddity out to make the mechanical minds struggle to understand why
Only two bolts won't constrain the pump in all directions, which leads to poorly aligned belts that wear out faster. Seven is probably excessive, though, I'll admit.
