91 Up Exhaust Hedder On 88 4.0
i think i may have a cracked exhaust manifold.the manifold for 87-90 is twice as much as the 91 + manifold. i have found some 91s that have flex joints built in.can you use a later manifold on the renix engine?
Have one welded into the new header.
I just found cracks in my #5 & #6 ports on my '88 manifold the other day so I'm in the market too. Is the EGR port the same size as the O2 bung? Just wondering because I can't weld it myself, if I pay a shop to do that, it might be cheaper to just buy the one made for 87-90 to begin with. There is one exhaust shop in my town and they are crooks.
I'm kind of debating about removing the stock manifold, having it welded, then putting in a flex section in the downpipe (should prevent it from happening again). Also, I know, I'd check the motor mount also.
