HOrnbrod Posted May 25, 2014 Author Share Posted May 25, 2014 Ill have to snap a few hornbrod, but I need to update my thread first. Ill try to do it in the next couple of days Your sway bar look like the below? If so, then it's an Addco. Link to comment Share on other sites More sharing options...
JoeLAW Posted May 25, 2014 Share Posted May 25, 2014 Nope not at all, I'm not surprised though since the PO did not make/install everything he did to the truck the way its supposed to be, since he runs a body shop all he cared about was looks... I'll snap a few pics today and try to post em tonight Link to comment Share on other sites More sharing options...
dankicksass Posted August 9, 2014 Share Posted August 9, 2014 Hornbrod is your Jeep lifted? I need to do this mod. Edit: ok I saw in a different thread you're lifted 3in. Mine is 3 as well. Really appreciate this thread. Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 9, 2014 Author Share Posted August 9, 2014 Yes about 2-1/2" now after a few years, via MT leaf springs and Teraflex shackles on the rear and OME 3" lift coils on the front. Link to comment Share on other sites More sharing options...
conker Posted August 9, 2014 Share Posted August 9, 2014 Any reason this specific writeup wouldn't work for a SWB MJ? Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 9, 2014 Author Share Posted August 9, 2014 The frame and shock mounting is completely different in the rear between the long and short beds. Here is a good writeup for the short beds: http://comancheclub.com/topic/42029-comanche-rear-sway-bar-short-box/ Link to comment Share on other sites More sharing options...
TheDude Posted February 2, 2015 Share Posted February 2, 2015 I want to do this to mine but, I have a Ford 8.8 in the rear now. I assume this changes what axle brackets I need? Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 2, 2015 Author Share Posted February 2, 2015 Yep, the 8.8 has larger diameter tubes. Pick up a pair of Ford Explorer rear axle sway bar u-bolts w. brackets and bush it for whichever bar you use; stock WJ or the ADDCO bar I used. Link to comment Share on other sites More sharing options...
TheDude Posted February 7, 2015 Share Posted February 7, 2015 Ok, cool. Now I just need to find a pair of those Dodge mounting brackets.. Link to comment Share on other sites More sharing options...
Blaine.D Posted September 10, 2018 Share Posted September 10, 2018 Does this work with the stock hard brake lines? Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 22, 2018 Author Share Posted September 22, 2018 On 9/9/2018 at 7:19 PM, Blaine.D said: Does this work with the stock hard brake lines? Good question - forgot to mention that. I have stock brake lines and to provide clearance I had to use a couple of 1/2" standoffs for the right brake line to clear the sway bar axle u-bolt. Link to comment Share on other sites More sharing options...
