So I am just about DONE with these vaccum leaks. So I have decided that I would replace all the hard vaccum line with new rubber vaccum line. I have found some Gates vaccum line from O'Reillys that seems would work.
I am asking if anyone else has done this and if so what brand did they use?
Here is the lines I'm looking at:
http://www.oreillyauto.com/site/c/search/Vacuum+Hose/N0890/C0222.oap
Hopefully this will fix my rough idle issue. I also plan on moving that vaccum canister more towrads the back firewall.
Just an update:
I moved the vaccum canister from the front passenger side bumper to under my coolant bottle. I plan on securing it down somehow but right now it is just sitting snug under there. I also managed to use all the old lines to connect to the bottle. Just the right amount of length. I like this re-location because it eliminated A LOT of vaccum line which is potential to leak.  :thumbsup:
I checked for any cracks or leaks before I used the old lines of course. Now I can tell there is a difference in my idle. Runs a bit smoother. Now I am going to replace the hard plastic vaccum lines with rubber. :wrench:
