ownedueasy Posted March 9, 2014 Share Posted March 9, 2014 ok guys i have a 92 comanche thats 2.5, 5 speed. i have all the 4x4 parts besides front axle, and drive shafts. i know that the front will need to be 25-5/16 inch, but whats the rear have to be after converted? and what is the length of the 2x4 drive shaft? Link to comment Share on other sites More sharing options...
jimoshel Posted March 9, 2014 Share Posted March 9, 2014 Measure yours and see? Link to comment Share on other sites More sharing options...
ownedueasy Posted March 10, 2014 Author Share Posted March 10, 2014 yes i can measure mine but is it the same from 2x4 to 4x4 on the rear? Link to comment Share on other sites More sharing options...
jimoshel Posted March 10, 2014 Share Posted March 10, 2014 No. The 4wd will be much shorter. There's a transfer case between the the back end of the tranny and the rear axle. Link to comment Share on other sites More sharing options...
Jeep Driver Posted March 10, 2014 Share Posted March 10, 2014 What parts do you have? I assume you have a 4.11 rear? Where are you looking for the D30? How did you come about what you have and not the front axle? You have the tube-in-tube rear DS, unless you find a shop that will shorten yours, you'll need to have one made. Link to comment Share on other sites More sharing options...
91Pioneer Posted March 10, 2014 Share Posted March 10, 2014 FYI it's called 4x2, not 2x4. 2x4 means you're talking about lumber LOL Link to comment Share on other sites More sharing options...
jimoshel Posted March 10, 2014 Share Posted March 10, 2014 Don't laugh. Grandad made a drive shaft for his '20's something International. using a Walnut 4X4. It was back during the war when parts were hard to come by and for a Missouri dirt farmer a dollar was even harder. Link to comment Share on other sites More sharing options...
Incommando Posted March 10, 2014 Share Posted March 10, 2014 There is a drive shaft length chart stickied on here somewhere. it will change depending on your rear axle as the pinion lengths on the diffs change. EDIT: Gotz it: http://comancheclub.com/topic/18925-looking-for-driveshaft-lengths-of-stock-trucks/ A lot of info in the DIY projects section Link to comment Share on other sites More sharing options...
