High Idle After Restart
Were the injectors upgraded from single port to 4 ports? Like I said I believe but not sure if there was a vacuum leak on mine all I know is it no longer restarting at high idle, maybe the older single injectors had sticking problems was the reason I changed them on mine and all is good now.
Yes I replaced the injectors with the Volvo injectors. The high idle was there before and after.
Of  course it was. The injectors have nothing to do with idle flare on start-up. It's TPS and it's related grounds/connections.
That's what I thought as well.
I'm still intrigued by the power latch relay. Might that have something to do with it? Some faulty interpretation by the computer?
First post has an index in it. Post 11 is TB and IAC cleaning.
Just in case anyone else wants to see the index, here it is.
Revised 03-04-2014
 Instructions have been written *
 Photos included with instructions **
1-Ground refreshing*
2-C101 connector refreshing**
3-Connector and relay/receptacle refreshing**
4-Coil/ICM contacts*
5-Checking sensor grounds*
6-Sensor ground upgrade**
7-CPS testing and adjusting**
8-TPS testing and adjusting**
9-ECU connector refreshing*
10-Trans plug connector refreshing*
11-Throttle body and IAC cleaning*
12-Setting your 4.0 to #1 TDC**
13-Renix Distributor indexing**
14-Restoring throttle butterfly adjustment*
15-Rear main seal diagnosis*
16-Vacuum test for exhaust restriction*
17-HO engine into Renix*
18-Improving the instrument panel ground**
19-Headlight harness installation*
20-4WD shifting tips*
21- Renix EGR valve test*
22- Renix vacuum harnesses**
23- CPS timing advance mod**
24-4.0 Engine date codes**
25-Valve cover mod**
26- Oil Filler cap Mod*
27- C101 Connector Elimination
