frankMart Posted February 14, 2014 Share Posted February 14, 2014 Hi! Can somebody run a VIN for me? I bought the rear half of this truck and need all the info I can get about it.... The VIN is: 1J7FT26EXKL607411. Is a 89 Base Comanche. Thank you! Link to comment Share on other sites More sharing options...
87MJTIM Posted February 14, 2014 Share Posted February 14, 2014 The 3rd and 4th digits don't match the '89 VIN sequence. Based on the VIN you listed, you have a 1990 base model, 2wd, with a 2.5 4 cyl. It must have been an early production unit. The 10th digit, "K", is a 1989 production year. The 6th position, "2," is the base model. A "3" would indicate Pioneer. Source: www.vehicleidentificationnumber.com Link to comment Share on other sites More sharing options...
frankMart Posted February 14, 2014 Author Share Posted February 14, 2014 Thanks! The title says it is a 89, and the guy told me it was a 4 cyl 5 speed, but the axle ratio is 3.55. He doesn't have the drivetrain anymore. Is there a way I can know which gearbox came with it? Maybe I copied wrong those digits, here is the picture of the VIN: Link to comment Share on other sites More sharing options...
JeepcoMJ Posted February 14, 2014 Share Posted February 14, 2014 The motor isn't a guarantee of good ratio. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted February 14, 2014 Share Posted February 14, 2014 Chrysler shows build date as May 17, 1989. Originally sold at Lancaster Jeep, Lancaster, California Options list doesnt show engine or trans spec. Shows engine code EPD and trans code DCK. It does show 3 .55 axle ratio though. its also Calif. Emissions, might be the reason for 3 .55 axle ratio and 5 speed if thats what it had. Link to comment Share on other sites More sharing options...
frankMart Posted February 14, 2014 Author Share Posted February 14, 2014 What do yo mean the motor isn't a guarantee? I bought it because for what he told me: 4 cyl 5 speed. And I thought 4 cyl + 5 speed = 4.11 ratio. Mine has a "Dakota" axle in the rear, and is 3.55. Link to comment Share on other sites More sharing options...
danbyrambler Posted February 14, 2014 Share Posted February 14, 2014 Autocheck shows: VIN: 1J7FT26EXKL607411 Year: 1989 Make: Jeep Model: Comanche Style / Body: Regular Cab 2D Engine: 2.5L I4 TBI Country of Assembly: United States SEARCH is a good tool SEARCH using Google is a better tool In the Google window enter site:comancheclub.com whatever u r looking for - - in this case site:comancheclub.com vin - - fast n easy - - works 4 all sites :thumbsup: Here's another: http://www.jeepforum.com/forum/f53/get-your-stock-specs-here-135806/ Link to comment Share on other sites More sharing options...
JeepcoMJ Posted February 14, 2014 Share Posted February 14, 2014 engine specs are guidelines for gear ratio not a guarantee this is AMC were talking about. you got hosed if you thought you're getting 4.11s. And it's a Dana 35 so worthless anyways. The Dakota rear is stronger. Go buy new gears, the search for years 4.11is never ending. Only once have I had a factory 4.11 d44...& I have owned 29 mjs Link to comment Share on other sites More sharing options...
87Warrior Posted February 14, 2014 Share Posted February 14, 2014 Why not open the differential and do math, (ring/pinion), to determine the gear ratio? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted February 14, 2014 Share Posted February 14, 2014 Why bother at this point. We know whats in it. You should do that before you purchase something, not simply assume that a guideline is unarguable fact. Link to comment Share on other sites More sharing options...
