onlyinajeep726 Posted February 10, 2014 Share Posted February 10, 2014 So... was crawling around under the XJ yesterday and noticed the my driver side UCA bushing sleeve (axle side) has slid over and is not centered like it ought to be. Tried using a long pry bar to pop it back in place, to no avail. Figured the fact that there's a lot of weight riding on the front axle, it probably is impossible to just pop it back in like that. Anyway, how could I get it back in place short of unbolting it and busting out a BFH? Can I even unbolt it while it's parked on the ground or would it be safer to do by jacking it up? Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted February 10, 2014 Share Posted February 10, 2014 Unbolt the arm, then rent a ball joint press and press the bushings back in Link to comment Share on other sites More sharing options...
