Confused. Please Help
i have an 89 comanche 2.5l with throttle body injection.  it has idled high, and rough since i purchased it, and i am at the point i would like to fix why.  so i start trying to diagnose it, simple stuff first, spark plug order, and the such.  i come to find out that i can pull the spark plugs off both rear plugs, with no change to the motor.  so i determined that the spark is getting to the plugs (pulled the leads off while its running and watched it) and there was spark getting to the plugs.  i went, and got 4 new plugs, thinking that would fix it, and there was no change.  i'm at a loss where to go next. fuel injector?  wouldnt that affect all 4 cylinders though? i recently replaced a bunch of the vacuum lines as well, to eliminate some small leaks that were present.  compression is 145 across the board, and it drives well enough, just backfires on decel, and has a high, rough idle.
I have the same motor and I noticed that compared to my 4 Liters it is grumpy when it is cold......revs high....runs rough......but once warm purrs like a kitten........the rule of thumb that I have taught my wife and kids (all jeep drivers) is that jeeps are happy when all gauges are more or less at 12 o'clock....
...I think part of the problem might be  you are running cold
I'm thinking thermostat as well for the coolant issues.  its behind the housing for the upper hose correct?  also i figured out the crappy running issue..  intake bolts werent tight enough.
Yes 2 bolts and it is out....put in a 195
As for the poor running, check the intake manifold bolts to be sure they're snug and you're not pulling unmetered air into the engine between the manifold and head. There are also a few hoses below the throttle body that end to crack and leak vacuum badly.
