tmaxx411 Posted February 7, 2014 Share Posted February 7, 2014 for those of you plagued by constant oil leaks due to the crappy plastic valvecover, this is for you. you can tell an aluminum cover by the location of the oil fill. it is dead center on the cover, as opposed to on the front what you need 1 aluminum valvecover off a 93+ 2.5L (mine was off a 93 wrangler) 1 98 dodge dakota 2.5l valve cover gasket 11 1/4-20 1"long bolts 11 washers for those bolts vacuum tubing for ccv system 19/32 tubing for the ccv valve itself install is pretty simple prep the new cover however you like (sand/paint/polish/etc.) pull the old cover off, unplugging the pcv system clean the mating surface thoroughly. put the gasket on gently place the cover on, and start hand threading the bolts in. tighten the bolts fully hook up the ccv system (big hose to airbox, and small one to throttle body start engine and check for leaks Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted February 7, 2014 Share Posted February 7, 2014 While this all seems very easy to do for most of us, could you include pictures of what you did just so a newbie or inexperienced wrencher will have a better idea of what's going on? A picture is worth a 1,000 words. Link to comment Share on other sites More sharing options...
tmaxx411 Posted February 7, 2014 Author Share Posted February 7, 2014 i will add pictures tomorrow, since its dark out now Link to comment Share on other sites More sharing options...
benjy_26 Posted February 14, 2014 Share Posted February 14, 2014 On 2/7/2014 at 2:58 AM, tmaxx411 said: i will add pictures tomorrow, since its dark out now LIES!!!! lol j/k. Pics would be cool, though. Link to comment Share on other sites More sharing options...
CullenJ94 Posted June 3, 2014 Share Posted June 3, 2014 any chance you could post pics of this done preferably the new PCV lines Link to comment Share on other sites More sharing options...
88whitemanche Posted June 3, 2014 Share Posted June 3, 2014 Well the vacuum lines aren't that much of a difference...just that it switches on the valve cover itself...the thick bottom one has to be changed to fit the ccv on the aluminum cover to the air box and the thin one from the top switches to the side of the aluminum cover and down to the side of the throttle body... This pic doesn't show much but if you compare it to yours(plastic cover) you'll notice the difference Link to comment Share on other sites More sharing options...
