Back Firing
Driving to work Monday morning about 5 miles from home truck starts bogging down and back fires through tailpipe. Pulled over won't start. I take of tbi cover starts up and drive to work (20miles) no problems. I get off work starts up drive about 5 miles same thing happens. Its being doing this the past 3 days any idea what it might be. 1990 2.5 tbi ax5
Could be fuel filter or TPS is getting moisture in it. I had to spray my '86's sensor twice a year. Sometimes the wires to the injector get frayed too. You can get "carb icing" with the TBI as well if the hot air hose from the exhust to the airfilter box is missing and you are in high air moisture and just above freezing temps.
   And as Cruiser54 points out, check your grounds because the spark will cut out if the coil loses ground.
I did notice today one of the wires to iac motor was broke. So I unhooked didn't change anything also smoke was coming out of tb when I shut off. will replace fuel filter and tps  has being replaced in last 6 months. thanks
I replaced wire harness to iac. Started up idles good 700rpm drove about 30 miles still good. Went to work still good drove home idels 1000rpm. looking tb looks like weld broke were throttle cable hooks on that opens up butterfly. Does anyone have a picture of a 1990 2.5 tb. I can show were it is broke. thanks
Were the yellow spring is. Its the bracket that holds in place throttle cable hooks on to. Want to know if I can spot weld bracket to the pin that goes through spring to bracket. there is about 1/4 of play  causing high idle.
