89 Jeep Comanche No Running Lights & Fuel Gauge Not Working
I have no running lights and have found out there is a fuse that keeps blowing (shorts out) its the parking 10 amp fuse at fuse block would this be the circuit for the running lights? and what should I do at this point ? pull the fuse block out and locate the wire and follow it down the circuit?  and problem number two my fuel gauge  isn't working what voltage does it operate on at the sending unit ?  I'm thinking that short at fuse block may be my problem to both !! any replys and or advice is much apreaciated thank you.
  • 4 years later...
