Headlight Switch And Dash Wiring
My dash wiring is an absolute nightmare and I'm looking to redo most of it-
right now the front parking lamps come on with the break lights and the junction box is black and corroded after being cleaned a little over a month ago. I am building a custom dash and want to run new wiring to the headlights abd rear running lights but am not sure what gauge and switch to use. I have plenty of heavy, medium and light gauge wire and quite a variety of stock and toggle switches.
Can I use one of the stock XJ dash switches (trans/defrost, etc) to run the headlights/running lights or is there too much power running through that circuit for the switch to handle? If not, what kind of switch should I use?
There is no relay for the headlamps in MJs or XJs. All the amps drawn by the headlamps go through the headlamp switch. That's why they burn up quite regularly, especially when upgrading the headlamps to a higher wattage bulb, like H4s. So, no, do not use a stock dash switch for the headlamps w/o wiring in an aftermarket HD headlamp harness w. relays (or make your own harness).
In a perfect world, the stock 60W/55W sealed beams pull a bit over 6 amps with adequate gauge wiring and no corroded connections to cause voltage drops. So you will need a switch with a rating of at least 10 amps. Where you get it is your problem - I don't recommend hot-wiring headlamps.
