Kkilmer87 Posted December 13, 2013 Posted December 13, 2013 Year, Make, Model. 1986 jeep comanche custom metric ton 140k approx Image, if available http://t.co/i3VrFUehvH. http://t.co/5O3gjP8c6h Engine / Trans / Transfercase / Front axle / Rear axle / Wheelbase 4 banger.....ax5....2wd.....beam.....amc20 4.10 Build date: (its on the driverside door sticker, in the form of month and year) ? 85 all I could read Current Location: Region will do, state, and area of state. Northwest ct to be sold to a kid in Albany ny for a project vehicle Status: Is it still on the road, is it in the junkyard? Project awaiting work? 4 banger still runs amc 20 sold to a member and my springs kept for myself mint frame and from bed forward was previously owned by a kid in Naugatuck ct Notes: Anything that makes this comanche different from the rest. Metric ton package and ax 5 with a 4 banger that's about as special as it gets Current owner: Well, you know. Put down who has it, the yard its in, or anything of that sort. Kody Kilmer (kkilmer87) I while be tracking its progress in the future
eaglescout526 Posted May 21, 2019 Posted May 21, 2019 Build date: 10/31/85. Ah, nothing like the devil's numbers on Halloween.
JMO413 Posted June 28, 2020 Posted June 28, 2020 TL62 *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ CGX Head Restraints-Outboard Seating, RR DDJ 5SPD MANUAL TRANS A881 (JA-41) EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GSC MIRROR - RIGHT BLACK HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 20 GAL FUEL WJD WHEELS - 15 X 7.0 STYLED STEEL
