aquiring93 Posted November 25, 2013 Share Posted November 25, 2013 Master cylinder was replaced 6 months ago, no issues since. However, today after two days of below freezing weather and no driving time in that time period, I came out to find that my clutch pedal just sank to the floor. I checked my reservoir and I couldn't see any oil whatsoever. I filled it back up and drove it around for about 20 miles and the clutch is fine again. No signs of leakage above the fuse panel. Any ideas on what the issue could be? Could it somehow be the cold weather? Link to comment Share on other sites More sharing options...
juan Posted November 26, 2013 Share Posted November 26, 2013 mine did just that a couple of weeks ago... I filled the reservoir with fluid before my fingers froze. My clutch was installed new 2 years ago. After the fill up all shifting fine - I do see a small drop of what I think is oil in the ground but the truck has always marked the driveway with a few drops... now I'm wondering if is actually oil or clutch fluid - too cold to look right now. Link to comment Share on other sites More sharing options...
ctxj93 Posted November 26, 2013 Share Posted November 26, 2013 Check the bellhousing. Mine is currently soaked Link to comment Share on other sites More sharing options...
87MJTIM Posted November 26, 2013 Share Posted November 26, 2013 The dreaded "internal slave cylinder" stikes again! Check the floor/ground under your MJ. You may find your fluid there. Link to comment Share on other sites More sharing options...
ComancheKid45 Posted November 28, 2013 Share Posted November 28, 2013 The line from the master cyl. to the Slave could be failing as well... Link to comment Share on other sites More sharing options...
aquiring93 Posted November 29, 2013 Author Share Posted November 29, 2013 I arrived in Texas where the temperatures are warmer and I haven't experienced any leaking so far. Not sure what is going on. The line from the master cyl to the slave is fine. I'm not sure how to figure out if the slave is leaking or not. It seems really coincidental that it isn't leaking anymore now that I'm in warmer climate. Link to comment Share on other sites More sharing options...
