jimoshel Posted November 20, 2013 Share Posted November 20, 2013 I'm getting ready to swap all the gauges from a '88 instrument panel to a '85 instrument panel.Just curious to see if it will work or not. What I would like to know is whether or not someone has already did this. Save me from having to re-invent the wheel so to speak. All I really need is to swap the gas gauge to convert a 3/4 panel to a full panel The reason for swapping all the gauges is so the faces match. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 20, 2013 Share Posted November 20, 2013 I have not, but I've done several Renix - HO cluster/gauge swaps and vice-versa. Are you swapping a full set of six gauges from an 88 cluster into a full six gauge 85 cluster? If so, yes it will be fine as the cluster housings and gauge / indicator light circuit foils are the same. Assume the speedo cable should be the same too. Link to comment Share on other sites More sharing options...
jimoshel Posted November 20, 2013 Author Share Posted November 20, 2013 I have a '86 3/4 cluster. The BIG gas gauge and no tach. I have a bunch of ''87 up full panels. I want a '86 full cluster, small gas gauge in the lower left hand and a tach. Speedo cables are the same. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 20, 2013 Share Posted November 20, 2013 Should work fine then if the '86 3/4 cluster has temp and oil pressure gauges. What about the engines for the correct tach sync?I haven't done that one... Link to comment Share on other sites More sharing options...
jimoshel Posted November 20, 2013 Author Share Posted November 20, 2013 It'll be going into a 2.8 6cyl. The '88 is from a 4.0 6 cyl so that parts OK. I have a '86 with idiot lights and I'm going swap the full cluster into it. Also there's a couple guys advertising for a fuul cluster under wanted so maybe I can sell a couple. Get the tach to work with a 2.5. Link to comment Share on other sites More sharing options...
carnuck Posted November 20, 2013 Share Posted November 20, 2013 my '86 got an '89 gauge set. I just swapped the senders to make it work. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted November 20, 2013 Share Posted November 20, 2013 If you're putting a tach from a 6-cyl. into a 4-cyl. Jeep, your best bet is to get a cluster from a '90 XJ or MJ. They have that little potentiometer on the tach circuit that be adjusted to show the correct RPM's. I've done it with success before I did my engine swap in my MJ. Link to comment Share on other sites More sharing options...
