I knew when I bought my MJ it had minor holes on the driver side floor. It's time to fix them, but I need some help.
I'll get pictures up soon, but the hole resides under the accelerator pedal, maybe 3 or 4 inches long, 1 inch wide, pretty much where your right foot rests. I'm not a very good welder, and I'd rather not pay someone to do this for me. The most I've welded are shock mounts. If I neutralize the rust, could I just use a few layers of fiberglass sheets and resin? If not, what would be the best, non weld way to fix the hole?
1. Buy 16 gauge piece of sheet metal, 12 is the very thickest, 20 very thinnest.
2. Use grinder to cut semi appropriate size.
3. Use hammer to bend/shape piece of sheet metal to fit.
4. Use drill and rivet gun to fasten new piece of steel to floorboard
5. Seam seal the sh*t out of it.
6. Have a beer (root beer if under age/don't drink)
7. Call it good.
:thumbsup:
7. Call it good.
:thumbsup:
This is good advice if you're not a welder or don't have access to one. The only thing I would add is what PFCLeist suggested, for seam sealer use a few layers of fiberglass sheet and resin. Works well, lasts a long time.
Damn, kinda was hoping the fiberglass would do the trick alone. I do have access to a welder, would it just be easier to do some practice welds and go at it? I've dealt with rivets before, they're kind of a pain in the @$$. Thanks for the help guys
I used 'gass to repair a 2"X6" hole in the floorboard of a '65 CJ5. It held up for 12 years. That's when I sold it so don't know how long it lasted. Primary job was cleaning, removing neutralizing the rust.
I was inspired by Jims story and patched em with fiberglass, did an outstanding job, 6 layers thick (3 top, 3 bottom), probably even stronger than a metal sheet. Thanks for the help
I did the same with the old 914 I drove back in college days onward until 2004. I used spare scraps of 6-oz ding repair 'glass for surfboards I had accumulated for years along with a doubled section of heavy-weave 'glass roving plus a few layers of 'glass mat from boat repair. The resulting patch was a quarter-inch thick and plenty strong. I ended up making my own seat mounts that dropped the seating position a bit more than an inch - the patch provided plenty of security for the bolts I ran through holes drilled through glass and what metal remained.
I took 2 weeks prepping the rust with a chipper, wire wheel, and Ospho (phosphoric acid rust treatment) before priming, painting, 'glassing, gel-coating, re-priming, and re-painting. When I was done, you couldn't tell by looking at it that it had been repaired - the fiberglass patch even duplicated the original contours of the factory sheetmetal. It was plenty secure for nearly 20 years... right up until the day Hurricane Ivan dropped a 30"-diameter pine tree right down the middle of the car.
