1990 Sport Truck Concord, Nc
I will post Jeep porn tomorrow, since it is dark outside. You will see what I will be dealing with.
I just picked up my first MJ today for $800. It runs and drives. It is a White SB 1990 5 speed 4x2 4 cyl. I have wanted one for a long while now. The body is pretty straight, with just some minor dings in the bed and surface rust on different parts of the truck itself. Bear in mind, this truck has had some pretty good PO's. The parking lights stay on all of the time, The headlights and tail lights flicker on and off at random times, but mostly staying off. don't even get me started on the wiring. Its a freaking nightmare of splices and rerun wires. I hate electrical gremlins.
My next weeks plans are to change all fluids and get the lights working correctly. I have a 2013 manual trans FR-S for daily driving duties as of now. The MJ will become my DD when it is 100% road worthy. It will see mild offroading, even if I convert to 4x4.
Long term plans are as follows, using RyanMurph as a guideline, but not going nearly as in depth and to the detail he did:
Newer Front clip
Newer dash
4.0 conv
Auto trans
mild lift
31" AT's
Right now, I kind of dig the bench seat, so I may keep it still. I MAY convert to 4x4. This truck will be used for DD duties and to go hunting. I will go to Uwharrie for LIGHT wheeling,but mostly for camping. I will be asking A LOT of questions, so please be patient with me. Up the Irons.
Jason
***EDIT***
The floor boards are shot, like I figured they would be. I am no electrical guru, so the rats nest of wiring will be thrown out eventually. It looks like I will be driving it as is until after the first of the year, that is after I figure out the headlight/tail light situation. The bench seat will go when I upgrade the console, wiring, and interior.
List today(11-6-13)  in order of need:
Lights fixed
Horn fixed
Floor Boards patched
Line the cab
Head liner/behind the seat liner (Using an existing XJ headliner with soundbar)
Line the bed
Upgrade the engine/tranny
Upgrade the interior, including the dash/wiring, HVAC, and center console
Bucket seats
Upgrade doors (Hopefully keeping manual windows)
Upgrade axles
3-4.5" lift
New rims/tires
Paint
Undercoat
Possible 4x4 conversion (If I find a donor XJ)
I spent all day on the freaking headlights. They come on fine, but after a few seconds start flickering, regardless if the engine is running or not. I checked all grounds I could find. If you see the rats nest of wires, you will understand my dilemma. I heard the headlight switch clicking and bought a new one assuming that was it. That didnt fix it either. The wires are getting pretty warm too. I need help! LOL I have googled and searched to no avail.
Clicking can be heard when the headlights are turned on?  Sounds like a bad headlight delay timer.  Pull the fuse labelled "HD LP DLY" and see if that makes a difference.  I wish you lived closer, I'd be willing to help you figure it out.  Electrical isn't too terrible, to me at least.
I've looked under everything. I don't see a ground on the drivers side anywhere. That may be the problem. Lol
RyanMurph, you have an extremely nice MJ. I will be converting this over as soon as I build the funds up to purchase a suitable XJ donor.
My lights are still flickering. As I stated, the harness that plugs into the back of the headlight switch, the wires are getting warm. I see a spade connector on the switch itself with nothing connected to it. Is this to ground the switch or is it not used?
Thanks for the info. I would like to keep it spring under if possible, but may go that route if I don't convert to 4wd.
I am at my wits end about the lighting situation. I am not kidding when I say EVERY wire on this truck has been spliced. Hell, some of the splices even have splices. The reverse lights stay on all of the time as long as the tranny is in reverse. I buttoned everything back up and pulled it out of my garage and let it run for about 15 minutes. It runs fine, but as soon as I turn the lights on, the engine slows down at least by half. I am used to a little draw, but what its doing is not right. I know I won't be driving the truck that much until some other issues are addressed, mainly tires. I guess I will just drive it during daylight.
The best way to fix wiring issues is to just get rid of them.  The '97 conversion will solve all of your problems lol.
Have you tried an eraser wheel for the decals?  It works really well and doesn't burn through your paint.
I totally agree with your first sentence, and will just be using the truck to haul when its daylight until the tear down starts.
I am not worried about the paint. It will get sprayed once all of the body work is done and the engine is out. As of right now, I am going to keep it white.
