oldseddie Posted October 24, 2013 Share Posted October 24, 2013 While doing research for my 97+ conversion I learned that the cpu uses a vehicle speed sensor on the rear axle for 97 models and an ABS sensor on later models. I have a rare dana 44 in my chief and don't want to have to change it for a 97 axle to get the sensor input, but I also despise antilock brakes. What did you guys that have done this already used for speedo input? Link to comment Share on other sites More sharing options...
yxmj Posted October 24, 2013 Share Posted October 24, 2013 I have found that when the red lights flash in my rearview....I am going too fast..... :laughin: ...... . :MJ 1: . Link to comment Share on other sites More sharing options...
oldseddie Posted October 24, 2013 Author Share Posted October 24, 2013 Or not fast enough! Link to comment Share on other sites More sharing options...
Alexia Posted October 24, 2013 Share Posted October 24, 2013 The ABS option on Cherokee models was not common at all. I have only seen one in my life. If for some reason you have a 1997+ computer with ABS programmed into it simply grab a non-ABS computer for the same year. Link to comment Share on other sites More sharing options...
reece146 Posted October 24, 2013 Share Posted October 24, 2013 Are you confusing things, OP? AFAIK the VSS is in the transfer case tail housing (speedo gear). There is nothing on the rear axle for VSS. As for ABS, I thought it was a standalone system with its own separate controller (ECU)? I could be wrong though as I haven't had to deal with it. When I changed the rear axle on my 2001 XJ (C8.25 for FF D44) there was no electronics or sensors to deal with. Link to comment Share on other sites More sharing options...
oldseddie Posted October 24, 2013 Author Share Posted October 24, 2013 I talked with an old friend that is a Jeep tech at the dealership and he may have been confused as it has been awhile since he has seen one in his stall. I have a 97 wiring harness as well as a 98 and neither has abs. I was hoping an electronic sender from the transfer case of a 91-95 would work. Link to comment Share on other sites More sharing options...
reece146 Posted October 25, 2013 Share Posted October 25, 2013 Spidey-sense says there was a change from mechanical to electronic around `91-`92 and then the bus style and/or mechanical interface changed again around `96 w/ OBD2. I may be muddling YJ and TJ stuff in there though. Link to comment Share on other sites More sharing options...
