HughMann Posted October 13, 2013 Share Posted October 13, 2013 I purchased a MJ on the 4th of this month. It had been sitting since 2011 when the PO passed away until 4/9/13 when it was re-registered by the PO's wife and It had less than 100 miles from the inspection mileage when I bought it. The issue is that the little yellow low fuel light comes on at anywhere from 1/3 tank or less and will go on and off depending on if you are going up or down a hill or around a turn with some speed and sometimes it will just go on and off on flat ground. I am guessing part of the problem is that it has only had maybe 2 tanks of gas through it since 2011, but is there a fuel level sensor that might need to be cleaned? I am also guessing that the only options to change said sensor if there is one is to a) drop the tank or b) take the bed off. Am I correct on that assumption? Link to comment Share on other sites More sharing options...
TheReverendBill Posted October 13, 2013 Share Posted October 13, 2013 there are no baffles in the tank so the fuel will just slosh around. the cure I have found is to keep it above half a tank at all times Link to comment Share on other sites More sharing options...
HughMann Posted October 13, 2013 Author Share Posted October 13, 2013 there are no baffles in the tank so the fuel will just slosh around. the cure I have found is to keep it above half a tank at all times sounds reasonable. Link to comment Share on other sites More sharing options...
gogmorgo Posted October 13, 2013 Share Posted October 13, 2013 Mine typically does that too. Also, I once dropped my tank (was going to replace it but the replacement Napa sent me was an Xj tank) after the low-fuel light came on, and then could barely lift it back into place with the fuel still in it. So I drained it, and there was still 10 gallons in it... Link to comment Share on other sites More sharing options...
cruiser54 Posted October 14, 2013 Share Posted October 14, 2013 Refresh the ground for the fuel pump and sending unit behind the driver's side taillamp assembly. Link to comment Share on other sites More sharing options...
