Floor Pan Recommendations For 86Mj
Just about any quality 'Front XJ' floor pan will fit pretty well. These usually stop around the first set of seat mounting bolts. The pan will likely need to be modified to fit around the small cab brace. You are 100% on your own for the rear. I bought a piece of sheet metal in about the same thickness as the front XJ pan from the hardware store and banged it into shape. The rear XJ pans won't work well as the MJ floor dips on either side.
I bought a Raybuck floor pan. Deemed by many XJ'ers to be the 'bees-knees'. It arrived and fit well, but it did have a
Key Autoparts sticker on it. Key was cheaper, so I'd suggest looking for one of them. I have used Sherman XJ rockers and they fit great, so I would also consider Sherman floor pans.
Oh yeah, that 86-01 MJ floor pan will fit like a peach.....
I purchased the full set of C2C MJ floor pans (and rockers) for my 92. They are XJ pans advertised as fitting the MJ and fit as well as a square peg in a round hole. I would advise against anything C2C advertises being built for the MJ from personal experience. Their XJ pans being sold as MJ pans would fit an XJ poorly. It seems as if bangobill80 has had a similar experience with the C2C pans.
In deed I have comanche fanatic They suck! I have fixed the pans in a 77 ford 150 79 dodge power wagon 81 mercury cougar and various othrr smaller fooor.patchs and never bought pans just fabed them myself thought I would be able to do a nicer job with preformed pans.stuck useing them because I lost the receipt.
