mjeff87 Posted April 10, 2007 Share Posted April 10, 2007 Anyone run one of these? I've got the chance to pick one up for short cash once the wife and I get back from vacation next week (instead of building one). It's not a winch bumper :cry: , but does have a 2" receiver. I may have to trim the front fenders for it to fit, but I was planning to do that, eventually, anyhow :brows: Any comments welcomed.... thx, Jeff Link to comment Share on other sites More sharing options...
87manche Posted April 10, 2007 Share Posted April 10, 2007 does it have unibody tie ins? Link to comment Share on other sites More sharing options...
mjeff87 Posted April 10, 2007 Author Share Posted April 10, 2007 This is the only pic of it I have....haven't seen it yet in the flesh. Looks like short sections drilled for the 3 bumper bracket bolts is all (but I snagged a copy of that tie-in you posted, and could have a set of those made and welded on in place :D ) Jeff http://new.photos.yahoo.com/onehighxj/a ... 96009355/6 Link to comment Share on other sites More sharing options...
87manche Posted April 10, 2007 Share Posted April 10, 2007 make the tie ins and it will be plenty strong. I wouldn't weld them to the frame though, as I think the forces involved in revocery might cause the welds to induce stress fractures in the front end. I'd bolt them. Trust me, if you catch the sleeved bolt hole already in the frame with a 1/2" grade 8 bolt you're not gonna pull it out :D also, the tie ins go on the outside of the frame, so the bumper must bolt to the inside, or you'll have to modify the bumper so it will work with the tie ins. Link to comment Share on other sites More sharing options...
mjeff87 Posted April 10, 2007 Author Share Posted April 10, 2007 not gonna weld to the frame, just gonna replace what's on there with new tie-in's Jeff Link to comment Share on other sites More sharing options...
pingpong Posted April 11, 2007 Share Posted April 11, 2007 Depending on how much it is, it can be modded pretty easily, I would definately beef up the mounts, but thats just me :brows: Link to comment Share on other sites More sharing options...
87manche Posted April 11, 2007 Share Posted April 11, 2007 not gonna weld to the frame, just gonna replace what's on there with new tie-in's Jeff I'm still not sure I would weld them on like that, because then if you had to take off the bumper to get at anything, or even to repaint it you'd have to unbolt the steering box. After fighting to get it back into place the other day for 45 minutes, I don't think I'm ever unbolting that bastard again, until it breaks. The JCR bumper bolted to the plates using the stock three holes, I think that they would be more than sufficient. Not sure what the breaking point is for 3/8 gr8 bolts, but it's gotta be a lot. Link to comment Share on other sites More sharing options...
pingpong Posted April 11, 2007 Share Posted April 11, 2007 I can tell you I snapped a 3/8 grade 8 bolt with a 2 foot cheater bar :eek: You just havent changed your steering box enough... I can swap one in about 20 minutes :brows: Link to comment Share on other sites More sharing options...
87manche Posted April 11, 2007 Share Posted April 11, 2007 I can tell you I snapped a 3/8 grade 8 bolt with a 2 foot cheater bar :eek: You just havent changed your steering box enough... I can swap one in about 20 minutes :brows: I've snapped 5/8 bolts with a big enough breaker bar, but that's a torsional load and not a shear load. I think it would take a lot more to break it under a shear load. Link to comment Share on other sites More sharing options...
87manche Posted April 11, 2007 Share Posted April 11, 2007 so I got curious and had to find the numbers. a 1/4" grade 8 fastener had a shear strength of 4700 lbs a 7/16" gr8 bolt has a shear strength of 15900 and a 1/2" gr8 bolt has a shear strength of 21300 I went out and looked at the bolts supplied by JCR, they were not 3/8, but rather 7/16. So, a single gr8 7/16 bolt is capable of almost 16K pounds of force before it shears. I think it's gonna be alright, considering there are 6 of thsoe holding it to the tie in plates. Link to comment Share on other sites More sharing options...
mjcanoe Posted April 14, 2007 Share Posted April 14, 2007 mjeff87, looks good. I dig your AMC logo, how did you do that? I'm new to this i-net stuff, pics., avatars, etc., so I have no clue. mjcanoe Link to comment Share on other sites More sharing options...
mjeff87 Posted April 16, 2007 Author Share Posted April 16, 2007 mjeff87, looks good. I dig your AMC logo, how did you do that? I'm new to this i-net stuff, pics., avatars, etc., so I have no clue. mjcanoe Sorry for the late reply.... Find a small pic that you want to use as your avatar, and save a local copy of it on your PC. Then, under your Profile, scroll to the bottom of the page and enter the path to the file where you saved it, and click upload. The pic cannot be larger than 150X100 pixels, and 21 kb. If it is, you can resize it. Jeff Link to comment Share on other sites More sharing options...
mjcanoe Posted April 16, 2007 Share Posted April 16, 2007 Mjeff87, thanks for the info. When I get smarter w/PC's I'll make it happen. mjcanoe Link to comment Share on other sites More sharing options...
Pete M Posted April 16, 2007 Share Posted April 16, 2007 Or you can email it to me and I'll do it for you. :D Link to comment Share on other sites More sharing options...
mjeff87 Posted May 4, 2007 Author Share Posted May 4, 2007 Well, I ended up getting it last night. It'll work for now, until I scrape up the money for a winch, then I'll build a winch bumper. Compared to Pat's rear bumper, this Tomken is considerably lighter ;) . It doesn't have D rings, but it has a receiver. The tie-in plates are meh.....they only use the 3 bumper bracket bolts. I'm going to have a set of those other plates made up and get them welded in place of them Overall, for what I paid for it, it's decent. Pat, I bought it from a buddy of yours (Randy) from MPJAI. He's in school here at VCU, and says "hey" :D Image Not Found Image Not Found Image Not Found Link to comment Share on other sites More sharing options...
speed_racer Posted May 4, 2007 Share Posted May 4, 2007 Yeah, DEFINITELY not ready for extractions in its current condition, but post up when you beef it up and mount it Link to comment Share on other sites More sharing options...
pingpong Posted May 4, 2007 Share Posted May 4, 2007 Thats cool Rabdy is a good guy. Bring that on by the house when you come down... I think I might have some beefier plate to beef it up in the mounting area by then. I don't know what Tomken charges for that bumper, but it looks to be made out of 1/8 stuff, and if you are a jeep abuser or use your bumper as a ramp... It will bend :brows: The front of my Rigid CO bumper has some nice dents in it, and it is made out of 1/4 :hmm: Link to comment Share on other sites More sharing options...
mjeff87 Posted May 4, 2007 Author Share Posted May 4, 2007 Yeah, it's 1/8". I went to pick it up last night to put it in the bed and nearly threw it right over my head. I'm used to handling....heavier stuff :rotf: Link to comment Share on other sites More sharing options...
pingpong Posted May 4, 2007 Share Posted May 4, 2007 That bumper doesnt look too hard to make either.. I don't know what they charge for it, but I am sure it is too much Link to comment Share on other sites More sharing options...
87manche Posted May 5, 2007 Share Posted May 5, 2007 http://www.tomken.com/detail.php?id=120 $325. seems a bit steep for what it is. good score for what Jeff paid though. Link to comment Share on other sites More sharing options...
mjeff87 Posted May 24, 2007 Author Share Posted May 24, 2007 Got inspired last night after work and decided to test mount it. For now, I tied the brackets into the tow hook brackets (including the L shaped front ones) I already have on. I had to notch out the front of the tow hook brackets a tiny bit, but other than that, it was a bolt-on job. I’ll probably end up taking the tow hook brackets off and building a new bracket altogether, so I can tuck it a bit further back toward the grill. But for now, it’ll work. Couple pics….. Sticks out just a wee bit Image Not Found got to clean up underneath, but here’s a front shot Image Not Found had to notch the bracket a tad (in hindsight, I should have notched the bumper instead of the bracket, but oh well…..) Image Not Found Link to comment Share on other sites More sharing options...
CEThomas Posted May 24, 2007 Share Posted May 24, 2007 Looks good :D Link to comment Share on other sites More sharing options...
87manche Posted May 24, 2007 Share Posted May 24, 2007 time to start cutting up the front shetmetal :brows: Link to comment Share on other sites More sharing options...
pingpong Posted May 24, 2007 Share Posted May 24, 2007 Whenever we get a chance to catch up with each other, I will help you modify your jeep some more :evil: Link to comment Share on other sites More sharing options...
