skel130 Posted October 4, 2013 Share Posted October 4, 2013 I recently changed to gear oil in my truck, and like many before me, struggled to find a tool to remove the 5/16 square hole plugs. At a tool store, when attempting to find a tool to use, I stumbled upon the best solution I've heard of yet. I present to you.............. The 5/16th keystock. Cut a 2-3 inch piece, and use a 5/16 box wrench. Presto, open without having to A) Ruin a good 3/8 extension, or B) Worry about rounding the hole with a mis-ground extension. Looky here: https://www.acehomecenters.net/products/key-stock-sq5-16x12-red%7C54254.html Even ACE carries it. Wasn't sure where to put this little revelation, but hopefully someone finds this useful. Link to comment Share on other sites More sharing options...
reubj Posted January 24, 2014 Share Posted January 24, 2014 I replaced my drain plug with an M16 X 1.5 magnetic drain plug and the fill plug with an M18 X 1.5 oxygen sensor bung plug. No more special wrench needed. Link to comment Share on other sites More sharing options...
Rockfrog Posted January 29, 2014 Share Posted January 29, 2014 I picked up the goofy tool of e-bay a few months back for a couple bucks shipped ... 8mm and 10mm square drive sockets in the package for use with my 3/8" ratchet. keep them in the glove box. Link to comment Share on other sites More sharing options...
AeroNautical Posted January 29, 2014 Share Posted January 29, 2014 Look at my signature, it has never been more relevant than right now, haha. I found a threading tool with a square head that fit almost perfectly into the hole. I just used vice grips to clamp down the other end and turn. Worked like a charm, got it from Ace. Link to comment Share on other sites More sharing options...
jpdriver1 Posted February 4, 2014 Share Posted February 4, 2014 I picked up the goofy tool of e-bay a few months back for a couple bucks shipped ... 8mm and 10mm square drive sockets in the package for use with my 3/8" ratchet. keep them in the glove box. found these http://www.ebay.com/itm/TWO-PIECE-8MM-10MM-SQUARE-DRAIN-PLUG-SOCKET-SET-2049-3-8-DRIVE-/130896298601?pt=Motors_Automotive_Tools&hash=item1e7a070269&vxp=mtr Link to comment Share on other sites More sharing options...
8valvehero Posted April 30, 2014 Share Posted April 30, 2014 Bump. This needs to be in the "most important tip" sticky thread Link to comment Share on other sites More sharing options...
