Wj Booster And Mc Swap, Now No Brakes?
I just swapped in a new WJ booster with a used MC. Everything is hooked up and I made my own brakes lines with the correct flare for the MC and prop valve. When I go to step on the pedal or pump the brakes I don't get any pressure in the pedal. Am I missing something?
We had fun the last time we did the brakes on one of the systems. Bled everything, and went back through it about 5 times (going through three quarts of fluid!). Turned out I had to crack the lines free from the distribution block while someone pressed the pedal to remove the last stubborn air bubbles.
Had brakes after that.
