Knucklehead97 Posted September 24, 2013 Share Posted September 24, 2013 So I looked up under my brothers truck and I noticed a wet spot on the differential cover. And theres been a weird whirring coming from the rear at certain speeds/rpms. So I'm thinking he's low on differential fluid and that its leaking out of the weird plug on the differential cover. How do I get more fluid in? What fluid do i use? And how can I seal that plug? Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted September 24, 2013 Share Posted September 24, 2013 Buy a new fill plug, buy a LubeLocker gasket and get 2 quarts of synthentic 75W-90 gear oil. It's a simple process. Remove diff cover Let fluid drain Clean off old gasket/permatex Pop out old fill plug Reinstall cover with LubeLocker gasket Fill with gear oil until it just starts to come out of the bottom of the fill hole Insert new plug Done. Make sure you do all of this on level ground. Link to comment Share on other sites More sharing options...
mvusse Posted September 24, 2013 Share Posted September 24, 2013 To just top it off, pry the rubber plug out with a screw driver, top off with GL-5 gear oil, buy new plug from parts store. $2.99 at Autozone, similarly cheap everywhere else. Link to comment Share on other sites More sharing options...
yxmj Posted September 24, 2013 Share Posted September 24, 2013 Buy a new fill plug, buy a LubeLocker gasket and get 2 quarts of synthentic 75W-90 gear oil. It's a simple process. Remove diff cover Let fluid drain Clean off old gasket/permatex Pop out old fill plug Reinstall cover with LubeLocker gasket Fill with gear oil until it just starts to come out of the bottom of the fill hole Insert new plug Done. Make sure you do all of this on level ground. :agree: :thumbsup: Don't just top it up....for 5 minutes work you can do a complete change with new lube......and you get a chance to give it a quick visual; inspection......maybe the noise is more than low fluid....why guess when you can know for sure. . :MJ 1: . Link to comment Share on other sites More sharing options...
Knucklehead97 Posted September 24, 2013 Author Share Posted September 24, 2013 Well thats alot easier than I expected. He has a lift and the axle is rotated to correct driveshaft angle, its not much, but will it effect anything? Link to comment Share on other sites More sharing options...
yxmj Posted September 24, 2013 Share Posted September 24, 2013 Well thats alot easier than I expected. He has a lift and the axle is rotated to correct driveshaft angle, its not much, but will it effect anything? If anything the rotation will make the fluid easier to drain :thumbsup: Link to comment Share on other sites More sharing options...
Knucklehead97 Posted September 24, 2013 Author Share Posted September 24, 2013 Great! Thanks guys. Link to comment Share on other sites More sharing options...
