Firewall Connectors To Fuse Block
Does anyone know how to separate the firewall connectors from the back side of the fuse block?
I know that they are full of the tar that was in the C101 connector and that they have a bolt in between the two halves.....
Does anyone have a pin-out of the two connectors?
thanks
There is a bolt in the middle of the block. I don't remember for sure but I think it is 8mm. However it might be a 10mm. Remove the bolt and the back half will come out. There are 4 bolts holding the interior half to the firewall. One at each corner. I don't have the pin outs on the puter but one of the other guys will be on later and help you.
