mdwatson Posted August 27, 2013 Share Posted August 27, 2013 When the truck is in 4 low there is a loud whining noise but it's not as noticeable in 4 high. Also I am getting a pulsating deep growling vibration in 2wd at about 55mph on up and the faster I go the louder and faster the noise is. Truck is a 86 2.5 3-speed auto if that helps. Link to comment Share on other sites More sharing options...
FrankTheDog Posted August 28, 2013 Share Posted August 28, 2013 Have you checked the fluid level in the transfer case? Link to comment Share on other sites More sharing options...
mdwatson Posted August 28, 2013 Author Share Posted August 28, 2013 Yes, fluid level is good. Link to comment Share on other sites More sharing options...
yxmj Posted August 28, 2013 Share Posted August 28, 2013 Fast guess sorry to say chain is probably stretched not hard to fix if you can turn a wrench next 2 signs...thumping when you shift into 4x4.....hole in the side of the case........ Link to comment Share on other sites More sharing options...
86FUBAR Posted August 28, 2013 Share Posted August 28, 2013 The np 207 you've got uses spur cut or straight cut gears which have a tendency to be quite loud and not as strong as the helical cut or angled gears used in the np 231 which run much quieter . Iv read about many people using motor oil in their T cases to help quiet them down . I personally run one bottle of Lucas tranny stop leak in place of one equivalent bottle of ATF but not for any potential noise reduction as my truck is loud inside and out anyways . Link to comment Share on other sites More sharing options...
mdwatson Posted August 28, 2013 Author Share Posted August 28, 2013 Thanks guys! There is no clunking when I put it in 4wd that I can hear and I wasn't sure if the whine ment there was something going out. Found out today that the motor mounts are shot and need to be replaced and hopefully that will take care of the vibration. If not I'll be back asking more questions haha. Thanks again! Link to comment Share on other sites More sharing options...
