Tires
30x9.5s won't rub anywhere.  31x10.5s may rub a tiny bit on the control arms when at full lock.  this can be remedied by adjusting the steering stops of swapping on WJ lower control arms (which have a bend in them for tire clearance)
31s on Jeep rims (from a ZJ) under a stock 4wd with and WJ arms:
CRM1988, your question was about rubbing on the inner fender liners. The answer remains: 31x10.50-15. Those will not rub on the inner fender liners. They WILL rub slightly on the lower control arms -- so will 30x9.50s, probably, but less so. The solution is to use WJ lower control arms.
If you don't want any rubbing anywhere, and you don't want to change anything -- then the answer is 235/75-15s.
Get 31x10.50-15, then put a few washers under your steering stops...that's all of 30 cents and took less than 10 minutes including getting tools out and putting them away.
And just for a visual reference:
This is stock with 235/75/15
This is stock rear, 1.75" BB up front and 31/10.5/15 and 2" wheel spacers all around
Image Not Found
And yes that's the same truck. lol
