87manche1 Posted August 24, 2013 Share Posted August 24, 2013 Was at a pull a part and saw some dodge ram straight axles from a 98. Do u guys think they'll work I know ill have to remount almost Everything. And I don't know what they are maybe ill get some pics latter Link to comment Share on other sites More sharing options...
xjrev10 Posted August 24, 2013 Share Posted August 24, 2013 The front is a disco axle. Link to comment Share on other sites More sharing options...
87manche1 Posted August 24, 2013 Author Share Posted August 24, 2013 Yea are they a d44? Link to comment Share on other sites More sharing options...
87manche1 Posted August 24, 2013 Author Share Posted August 24, 2013 Looks like a d44 per internet. How strong are they. I would just weld the disconnect shut. Link to comment Share on other sites More sharing options...
ComancheKid45 Posted August 24, 2013 Share Posted August 24, 2013 I know the fronts were Dana 44s. The rears are likely Chrysler 9.25s or something like that. Theyll be full width so youll have to setup for that as well. Not many people go into swapping them for some reason but I wouldnt think it would be a terrible swap imo ;) Link to comment Share on other sites More sharing options...
87manche1 Posted August 24, 2013 Author Share Posted August 24, 2013 Neither do I pull a part is 125 an axle so it wouldn't be so bad even if I had to regear. Link to comment Share on other sites More sharing options...
mpace6a Posted August 25, 2013 Share Posted August 25, 2013 The 9.25, from what I've heard, is a fairly strong axle. The front is just a full width d44...not sure if high or low pinion though. never had an issue from the 9.25 in our dodge, and i have a heavy foot, and do alot of towing and hauling with it. Link to comment Share on other sites More sharing options...
87Warrior Posted August 25, 2013 Share Posted August 25, 2013 Folks tend to stay away from the Dodge front axles due to the CAD (not as simple to lock as Jeep) and the unit bearings. Link to comment Share on other sites More sharing options...
87manche1 Posted August 25, 2013 Author Share Posted August 25, 2013 I've heard u can swap axle shaft from pre 85 to a one piece. Have not heard about unit bearings worse then the cherokees looks the same as ours just bigger Link to comment Share on other sites More sharing options...
87Warrior Posted August 25, 2013 Share Posted August 25, 2013 I too have heard you can swap the axle shaft to get a one piece. Not sure on the cost as I have never looked into it. The unit bearing on the ram is like the Jeep. They tend to wear out faster with large tires (usually if you are going full width, a 37 is a small tire) and they cost a whole lot more to replace vs the bearings in a traditional hub. I have seen guys running ram axles with good luck. You don't see it too much because for the same $$$ you can buy a Ford or GM axle that is easier to work on and cheaper to build. Link to comment Share on other sites More sharing options...
87manche1 Posted August 25, 2013 Author Share Posted August 25, 2013 Highest I want are 35s around here people want crazy money for axles Link to comment Share on other sites More sharing options...
xjrev10 Posted August 27, 2013 Share Posted August 27, 2013 Highest I want are 35s around here people want crazy money for axles Your fine with a D30/C8.25 or D30/D44 combo. Leave the front a open diff and go easy on the throttle at full lock. Carry spare front axle shafts and go wheelin! Link to comment Share on other sites More sharing options...
