jeepaholic Posted April 6, 2007 Share Posted April 6, 2007 where can i find some long shocks? I have a ride height measurement from the coil spring bucket to the top of the fender (where shock stud goes thru) of 29"....I am not having much luck finding any unless I go with resevoir style....whewww ya talkin big $$$ then. Link to comment Share on other sites More sharing options...
DirtyComanche Posted April 6, 2007 Share Posted April 6, 2007 The largest monroe will be about that... As long as you put a stud elminator bracket on the top end. Maybe. Link to comment Share on other sites More sharing options...
Regger Posted April 6, 2007 Share Posted April 6, 2007 Yeah, you'll probably have a lot of trouble trying to find a shock that long with a stud... Either by, or make yourself a stud eliminator kit and then your options are endless... Just checking my rancho specs, shows me a bunch of shocks over 30" extended length HTH Ryan Link to comment Share on other sites More sharing options...
DirtyComanche Posted April 6, 2007 Share Posted April 6, 2007 29" ride height is massive though... I'd probably try to raise the lower bracket too. Depending. How much suspension travel does it have? Link to comment Share on other sites More sharing options...
Regger Posted April 6, 2007 Share Posted April 6, 2007 Oh Jeez.. I didnt read the ride height part.. I somehow thought he was talking max shock length... But yeah 29" is damn tall... jeepaholic, how much lift is that?... As dirty said, raise the lower bracket, and drop the upper bracket to get down to a more common size... Otherwise, you will be buy remote resoviour $$$$ shocks... Ryan Link to comment Share on other sites More sharing options...
hamilton Posted April 9, 2007 Share Posted April 9, 2007 Somebody was looking for the Monroe catalog. Here's the link: http://tenneco.com/frames/monroe.html Click on "Catalog Lookup", then select "Miscellaneous Application Information". Pages of shock dimensions with their various mounting configurations. Link to comment Share on other sites More sharing options...
jared Posted April 11, 2007 Share Posted April 11, 2007 stem eliminintors are your best bet, you can get probalby 2'', and the bar pin eliminators also raise your shock 1/2'' Link to comment Share on other sites More sharing options...
mudrunt Posted April 11, 2007 Share Posted April 11, 2007 check with rustys i have 27 or so ride height with my 6.5" lift and they had shocks in stock and to me withing 2 days. Link to comment Share on other sites More sharing options...
