350 Olds Diesel
Got a chance to pick up a low mileage, complete running 1980 Olds diesel. Just thinking it maybe too much engine for a MJ. Any opinions or thoughts on the matter? I really want to do a diesel swap but I want it to be practical.
You do not want that engine.  I had an 81 Chevy Impala wagon in 82 to 85.  Slow but ran fine on the highway, 27 mpg if I remember right.  But the head bolts were a problem, the injection pump was a problem.  I blew two heads 6 weeks apart. one on the left side, then the one on the right side.
Been reading up on it. Apparently they didn't use enough headbolts. Using a set Of ARP head bolts and heavy duty gaskets solved that. They didn't have a fuel-water separator in them..Most of the problems can be solved with the use of after market goodies. I think I,m going to pass on it just because of the weight. Close to 900lbs.
If that was closer I'd jump on it. 520 miles, Pueblo to Alamogordo. The bid is $550, reserve not met.
^Didnt you post about a 350 Olds diesel a month or two back? Something about a neighbor was selling a car for dirt, and you ended up scrapping the whole thing?
Yep. It was scrap and that's what I did with it.
So many of those cars got converted to gas engines as the engine is dimensionally the same as a 260307, 330, 350 or 403 Olds  while using the same mounting locations and patterns.... and the diesel really sucked. Last time I checked a rebuilt starter for one was like $150 versus $22 for a gasser. In the early 80's I bought several cheap Olds cars and pulled the small-block Olds motors to sell them to a local machine shop that also specialized in de-dieseling the Oldsmobiles and Chevy trucks that came with that diesel. With crappy reliability and 105 hp/205 ft/tq it was nobody's favorite.
Those GM diesels were a pice of garbage!!  Consider a mid to late 80s MB five cylinder turbo diesel. Parts are available engines are available and reliable with plenty of power. There is a jeep on craigs list in San Diago with MB diesel for sale if interested.
