A/c And Heater Vents? Help 87 Comanche
Without pics it's difficult to help you out. Find a known vacuum connector (there are several) in the engine bay and connect it to one of them. Confirm you have two lines coming from the canister which is located inside the R side front bumper. Follow the lines away from the canister until you see where they are connected. One of them should connect to a junction connector near the firewall. The loose line can be plugged onto that junction if there is room.
