2001 Comanche Crew Cab - Detroit Didn't But I Did!
  • Replies 58
upper rear door post cut   NOTE: The fabricated frame and cross-bracing must hold upper rear door post aligned
– floor pan / frame rail / rocker box are cut – Offset cut to use all of the driveshaft tunnel
Comanche rear  post / roof section and Cherokee rear door upper post / roof section – achieved
final Comanche Crew alignment.  It was a very big relief when the rear door was re- attached and all the door / body gaps were in alignment – we had a successful project in the making – just along way to go
Comanche  Rocker box section and Cherokee rear rocker box section  (the Comanche rocker box was narrower than the Cherokee at the transition point)
(the Comanche rocker box was modified to match the Cherokee dimension at the transition point)
  • Pete M locked this topic
Comanche Crew rear roof section after welding a 2.5” wide Cherokee ridged section to smooth transition piece from the Cherokee and a Comanche smooth rear roof section which was taller and tilted forward and down at the front for a rear roof spoiler effect
After the stretch the body line on the Cherokee ran up hill in the rear door.  The Comanche rear cab metal ridge must be cut out and moved up ¼” to re align with the Cherokee rear door and the bed shimmed up the same amount .
01 Cherokee rear clip – plastic gas tank mount (reusing a portion in Crew Cab)
87 Comanche rear frame – will mount Cherokee plastic gas tank here (where spare used to be)
Bed Rear Fender Flare Fabrication
The 87 Comanche bed original rear fender flare was the old style (early design did not match the lines of the late model front 01 Cherokee flare)
The plan to match the front and rear flares uses 2 front 97-01 Cherokee (left and right) fender flares
cut in the correct places to make one new late model rear flare
(the 01 Cherokee rear bumper extensions and rear fender flare did not fit the Comanche bed)
This picture shows the two front 01 flares cut and installed on the bed side
(the center seam will be molded into one seamless flare – perfect fit to the bedside)
  • Pete M unlocked this topic
