  • Replies 77
  • 5 years later...
Been a while. Got GSkc Metric Ton springs, and RE ZJ 3.5in coils installed.
Recently swapped out stuck calipers and pads. Stops great. I feel there might have been an issue from the beginning as it stops way better meow.
Next project, is bypass LSV. I'm going to do it the way of blocking port at dist block, install adjustable prop valve, and running rear hardliners to softline.
It actually sits fairly level. The2nd pic makes it look like it sags butt. The work F150s have a decent factory rake.
