coyote kid Posted June 26, 2013 Share Posted June 26, 2013 i had to replace my fuel pump in my 88 2.5 i also moved to a external tank in the bed instead of the one under it because it was rusting out anyway when i finished i had the fuel pump wired to a toggle switch just off my battery my real problem is that when i started it the truck ran fine but for some reason the volt gauge only read 12 volts so i tried with my multi meter and sure enough 12 volts so i replaced my alternator with a brand new one and i am still having the same problem Link to comment Share on other sites More sharing options...
coyote kid Posted June 26, 2013 Author Share Posted June 26, 2013 does the fuel pump and the charging circuit work together in any way? Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted June 26, 2013 Share Posted June 26, 2013 Maybe it's just me, but I fail to see any problem. If the truck runs fine and the alternator is putting out 12V, then what's wrong? Link to comment Share on other sites More sharing options...
coyote kid Posted June 26, 2013 Author Share Posted June 26, 2013 i don't think its charging becuase if i unplug the positive terminal it kills the engine Link to comment Share on other sites More sharing options...
relyt120 Posted June 26, 2013 Share Posted June 26, 2013 you should be getting something like 14v off the alternator if it is functioning correctly. Take that baby to an auto parts store and have em test it. Link to comment Share on other sites More sharing options...
neohic Posted June 26, 2013 Share Posted June 26, 2013 ... so i replaced my alternator with a brand new one and i am still having the same problem Twice now I've replaced an alternator with an parts store unit and had it fail right out of the box. Link to comment Share on other sites More sharing options...
jimoshel Posted June 26, 2013 Share Posted June 26, 2013 Pulling the pos plug, from the alt, should not kill the engine. The resulting spark will kill the alt. Try running a wire direct from the bat + to the alt output wire. Now pull the plug. See what happens. Link to comment Share on other sites More sharing options...
