pug Posted June 21, 2013 Posted June 21, 2013 I just finished installing brackets and now drivers side is hitting sway bar link. I have 4 1/2 coils with rc lower fixed control arms and re fixed uppers. Any ideas thanks
64 Cheyenne Posted June 21, 2013 Posted June 21, 2013 Adjustable lowers. Might want to check caster angle also.
pug Posted June 22, 2013 Author Posted June 22, 2013 Fixed lowers and fixed uppers. Replaced lowers with stock lowers still same problem.
johnnyc Posted June 22, 2013 Posted June 22, 2013 Swaybar drop brackets. They relocate the swaybar away from the coil springs.
mvusse Posted June 22, 2013 Posted June 22, 2013 Driver side what is hitting the sway bar link? Did you get the correct length track bar for 4.5" lift? And please tell me you got the toe-in set correctly after the lift.
pug Posted June 23, 2013 Author Posted June 23, 2013 Yes correct track bar. Yes hitting sway bar link and inside of coil is hitting back of bump stop on drivers side.
pug Posted June 23, 2013 Author Posted June 23, 2013 Lift Height Lower Control Arm Upper Control Arm 4.5” 15.75” - Stock Length 15” - Stock Length. My upper arms are 15 1/4 would this cause a problem
shelbyluvv Posted June 23, 2013 Posted June 23, 2013 Swap springs side to side and see if that helps. I have a nasty bow in my passenger side coil. The drivers side is fine. I swapped them and it switched sides. Could just be the coil. Some bow, some don't.
pug Posted June 23, 2013 Author Posted June 23, 2013 The coils are 4-5 years old. Never bowed before brackets
