Rear Brake Adjustment
OK MJ folks,
88 MJ, AW4, 4.0L D44 LSD.  I did the brakes all around about 6 months ago. They seemed to work fine...although a little weak.  Nice pedal and response, I bled the prop valve per the instructions I've read on here.  I thought I had done the adjustment fine...but...apparently I did NOT.  I grew up on drum brakes, so I know how they go together, I'm just a tad confused.
Anyhoo, I went about the task of checking and re-adjusting them today. By the way the Chilton manual totally sucks for Cherokee/Comanche brake instructions.  There's no decent picture of the brakes.
So I finally got the thing turned to where I could not move the wheel by hand...then...it says to back it off 15-20 turns.  Does that mean "revolutions" or stabs (a stab =  about 1/8 turn).  That seems excessive.  So, frustrated agan I took the wheel and the drum off.  15-20 stabs = ~ 2 to 2.5 full revolutions of that star wheel, which almost completely closes the adjuster.
I did what it said to do, put the drum and wheel back on, with the rear jacked up, I started the Jeep, put it in D and the rear wheels started going...but applying the brakes barely stopped the wheel, and when I gave it a tiny bit of gas, the wheel started going again.  So, I surmised that it was "backed off" way too much.  I cranked it back to solid, and backed it off about 5 stabs, til I could move the wheel with only a tiny bit of drag.  So, just as a point of info, before I do the other wheel (the same way):  Is that right??
iirc ...to fully adjust the rear drum brakes you put it on all four tires and ride in reverse a few feet and drive around to try the brakes then if they are too loose to readjust them again.
I could be wrong but I remember an instructor in auto mechanics class saying that...
:agree:
When I had to adjust my brakes what finally worked was backing up about 10 feet and hitting the brakes. After a couple of times of doing this they worked fine and I havent had to touch them since.
Yeah, I did that 6 mos. ago...seemed inconclusive.  Thus my inspection today.  The brake shoes are 6 mos. old and look brand new, so I don't think they were doing much good.  Since I only drive the thing 2-3 times a month I've been remiss in fixing things.
:agree: I put ZJ rears on my XJ and haven't been happier.  Makes a world of difference in braking, BUT I also have the '95-'96 dual diaphragm booster and MC installed.  Haven't swapped the guts of the prop. valve yet.  When I get a chance, I'm going to do this upgrade to my MJ.  You can't go wrong with this and it's 20x easier to work on discs than drums.
  On 6/13/2013 at 3:45 AM, hornbrod said:
Charlie, just junk the rear drums on that D44 and install some Ford Explorer or ZJ disks and no more problems. Never look back and better brakes too. Win-win.  :cheers:
Yep, this is also on my list.  I have been looking for an 8.8 to swap in with 4.10 gears as I have a D30 with 4.10's all shined up and re-sealed sitting ing storage (I currently have 3.07's).  But right now I have to work with what I have. I'm somewhat hindered by $$ and time...short on both these days.
