Pete M Posted June 12, 2013 Share Posted June 12, 2013 sounds like the bearing in my XJ's alt isn't long for this world. Link to comment Share on other sites More sharing options...
Geonovast Posted June 12, 2013 Share Posted June 12, 2013 99% sure they are not. Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 12, 2013 Share Posted June 12, 2013 Not Pete. The HO NipponDenso alts are regulated by the ECU and the Delco Renix alts are regulated internally, so different wiring. Also the mounting points are different. Link to comment Share on other sites More sharing options...
Pete M Posted June 12, 2013 Author Share Posted June 12, 2013 :thumbsup: didn't think so be wanted to be sure before hitting the junkyard again. this "free" XJ is sure costing me a pretty penny to get it running right. :ack: (not that it's a surprise to anyone) Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 12, 2013 Share Posted June 12, 2013 It's probably the standard 90A alt, so look at the donor p/n on the tag for a bolt-in upgrade. The 136A was in the V8 Grands and Dodge trucks and it fits well. Mine just bolted in, but some guys have had to do some minor grinding on the brackets so they will fit. :thumbsup:56005685 XJ,YJ,Z; 90 Amp.556026811 1 X1; 117 Amp.56005686 ZJ V8; 136 Amp Link to comment Share on other sites More sharing options...
Lemmon714 Posted June 12, 2013 Share Posted June 12, 2013 Pete, Not sure if you are a cheap-o like me- I rebuilt two Denso alternators using the attached link. I did not replace the bearings, just the brushes. You should look at the slip rings on the rotor shaft to make sure they are not excessively worn. I think they are replaceable, I didn't change them on my alternators. http://www.jeepforum.com/forum/f11/rebuilding-nippon-denso-alternator-00-01-56041822aa-835511/ Dave Link to comment Share on other sites More sharing options...
64 Cheyenne Posted June 12, 2013 Share Posted June 12, 2013 The 136A was in the V8 Grands and Dodge trucks 56005686 ZJ V8; 136 Amp Don, isn't this an interchange for an HO? and if so isn't it internal regulated and Pete has a Renix? Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 12, 2013 Share Posted June 12, 2013 Pete was referring to his new not-so-free 96 XJ. :yes: Link to comment Share on other sites More sharing options...
Pete M Posted June 12, 2013 Author Share Posted June 12, 2013 yes, the 96. and a 136 alt sounds reeeealy good at the moment. guess I'm driving back out to the junkyard soon. :D Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 12, 2013 Share Posted June 12, 2013 Pete, here are the vehicles this alternator resides in: Link to comment Share on other sites More sharing options...
mvusse Posted June 12, 2013 Share Posted June 12, 2013 A Renix alternator can be used on an HO enigne, but you'd need to change the wiring, and possibly use a Renix bracket. I have seen one used on a 99 based stroker. Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 12, 2013 Share Posted June 12, 2013 Sure, it's possible, but why would you want to do it? It makes better sense to put a larger HO Denso alt in a Renix by changing the bracketry and adding an external regulator. Link to comment Share on other sites More sharing options...
mvusse Posted June 12, 2013 Share Posted June 12, 2013 The one i saw the owner paid good money to have it modified for 180 amp output a year earlier. He didn't want that money to go to waste. Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 12, 2013 Share Posted June 12, 2013 Okay, I can sure understand that. Link to comment Share on other sites More sharing options...
