Oddmodman Posted June 8, 2013 Posted June 8, 2013 Anybody know if a 94-99 ax-15 shifter will work in a pre-94 ax-15?
Oddmodman Posted June 8, 2013 Author Posted June 8, 2013 Never mind. Apparently year doesn't matter, only application; xj/mj and yj/tj.
MJRemi Posted June 9, 2013 Posted June 9, 2013 Be aware some shift levers from yj/tj vary in angle and can make contact with the dash in a MJ. You can transfer your MJ lever over if you need to.
