air filter
are you looking for a cone filter? what are the dimensions of the area you can fit it in?
i recommend a K&N cone filter and that has a 3" inlet...then get some 3" stainless tube for your intake tube and make a mount for the lower end of it and BAM got yourself a nice washable cold air intake.
right here is exactly what i have.
http://rustysoffroad.com/mm5/merchant.mvc?Screen=PROD&Store_Code=rustys&Product_Code=XJAT-1&Category_Code=PER_AIR
http://rustysoffroad.com/mm5/merchant.mvc?Screen=PROD&Store_Code=rustys&Product_Code=RE0810&Category_Code=PER_AIR
it went on easy enough and fits well. only thing is, it doesn't have a separator behind the filter. i am going to make one for mine here this summer out of some aluminum sheet metal and then heat shield stuff.
and here is a pic of mine.
Alex
i've got the same one as GIRSMJ
rusty's airtube with 6x9 k&n filter... they don't technically filter as good as paper filters. but they do sound nice.
actually a friend of mine is a mechanic and he says in order for the K&Ns to filter better then the paper ones, don't clean em as often as they say to. he said if they are REALLY dirty clean em, but unless you are driving through dust storms and stuff all the time then don't. he says that at his school, the tests they ran on filters to see what worked the best, the K&Ns work best when they are dirty. don't ask me why but that is what their tests came up with.
Alex
Alex
well good then, cause mine is not-so-well oiled/cleaned... i don't think anyone has oiled it since tim bought it 2 yrs ago actually :roll:
In order to filter as well as a paper filter, the K+N has to be partially clogged? And if it's partially clogged, wouldn't that mean it's not flowing better than the paper anymore? That's why I'm dumping the dang thing. Way too much hassle and too many questions about whether or not it's working right. And the paper one still filters better. Just be sure to buy a decent paper one. The Mopar one we got for the Libby is light years beyond the schmuck filter that came out of it, both in design and craftsmanship.
There are differing opinions on this so it's up to you to decide. There are also other options out there, like foam or the better-than-paper-but-didn't-require-oil ones I've seen but can't remember the name. I saw it in a 4x4 magazine a while back. Don't know if I'll be able to find it though.
Personally, my particular truck doesn't need to "breath better", that applies mostly to higher RPMs where the engine is asking for as much air as the system can flow and my truck doesn't see much of that. Also, with the places I go, my truck needs all the protection it can get. comanche.gif
