I'm going to install a 2001 xj e fan and I need help wireing it. I purchased a electric fan wireing kit. However I want to wire it straight to an on-off switch. Without a temp sensor. The fan has 3 wires coming out of it. Which ones do I use and which ones don't I?
If the fan is from an 01 XJ, it's a single speed (two wires). XJs never had a 2-speed fan.
Not always true. Green is ground in older cars
Really? I did not know that, thanks for sharing. The write up is the first link I posted, it takes you to a post by skidoo. The links are just above the two transmission pictures.
These are them so you don't have to navigate too far to find them:
http://comancheclub.com/topic/32733-what-is-the-correct-way-to-hook-up-an-electric-fan/
http://comancheclub.com/topic/32861-electric-fan-stays-on/?hl=fan&do=findComment&comment=331350
Not sure why I didn't post them to begin with
