Another A/c Thread
So I found a website http://www.jeepair.com/ac/4-0-liter-inline-6-cylinder-139.php with most of the parts needed and was wondering what its missing to install A/C in my truck. I know I need to get the actual controls for inside the cab but other than that I'm clueless. I'm most likely going to have a shop install it once I gathered everything up since they'll warranty it. Any help would be appreciated. I'll keep reading up see if I can find anything. Thanks
I didnt read the above article, but I did the conversion in my 2.5. I had to pull the dash and original heater box assy and swap in an HVAC box assy that has the AC evaporator in it, with the AC controls. The HVAC box wiring plugged right into the original dash harness, as i was using 1986 donor parts for my 87. Other years may vary. I then added the compressor and the longer belt needed, added the condensor and lines. Then came the wiring. Some of it was already there, such as the AC compressor clutch wire, but the relays needed to be added. i found out from the 88 FSM posted here on Comancheclub, that the 2.5's had a plug on the driver side wheel well for dealer installed AC, and a wiring schematic for what was needed to get it working. I re created the wiring and it all worked. I also changed the mechanical fan to an electric fan and made it work when the AC was turned on as well. I had to convert the whole thing to run R134a, but that isnt any big deal. One of the best mods Ive done, next to adding power steering.
As stated, some of the wiring may be different between engines and model years, but it can be done. Good luck!
Good info in the DIY forum - -
adding AC to a non AC truck
Search is a good tool
:wrench:
Really?  try searching for "AC to a non AC truck"
What would be really cool, if on such occasions as this a LINK was posted... just sayin
