Ok here is my question. Is there a place that sells cab corner repair panels ? Also if there isn't what have you done to repair or replace it. Any help and info would be great. Thanks
No, and sheet metal. :thumbsup:    The best you can do is to find a JY comanche with its cab corners intact and cut them out, other wise you will have to fab your own, or let it ride. I will try and put up some pictures of my repair job and another a little later.
