comanche1989 Posted February 15, 2013 Share Posted February 15, 2013 Will an AX-15 5 speed and transfer case from a 1990 wrangler bolt on to a 1989 Jeep Comanche with the 4.0, and BA10? Link to comment Share on other sites More sharing options...
Geonovast Posted February 15, 2013 Share Posted February 15, 2013 Yup, the only issue you'll have is with the transmission crossmember. The AX-15 one has a dip in the middle, which will most likely be a necessity, being as the trans is from a YJ, and will be clocking the T-case up. Link to comment Share on other sites More sharing options...
Pete M Posted February 15, 2013 Share Posted February 15, 2013 I do believe you'll need the t-case shifter assembly from an MJ/XJ too. Link to comment Share on other sites More sharing options...
comanche1989 Posted February 15, 2013 Author Share Posted February 15, 2013 Thanks for the replys. This might sound like an amateur question, but can I put a transfer case on a 2wd transmission? I feel like you can't but I'm unsure Link to comment Share on other sites More sharing options...
Pete M Posted February 15, 2013 Share Posted February 15, 2013 not without major surgery to the trans internals. by the time you bought all the parts needed, you'd be far better off with just getting a 4wd trans. :thumbsup: Link to comment Share on other sites More sharing options...
comanche1989 Posted February 16, 2013 Author Share Posted February 16, 2013 Thanks for the reply! At my local pick and pull they have 2 cherokees so hopefully one of them is stick!! :bowdown: Link to comment Share on other sites More sharing options...
