codymanche Posted February 12, 2013 Posted February 12, 2013 Hey guys. Well we got the engine and tranmission in on the "big green truck" here in the last 2 weeks. So i hooked up the starter and started getting things plugged in but i don't know where the other side of the plug that it plugs in to. There is a plug that it can go into by the valve cover but thats the only one i see? Is this the right one. If some one has a pic of where it plugs in to could you please share the pic?
Geonovast Posted February 12, 2013 Posted February 12, 2013 The CPS has it's own plug, and connects on top of the intake next to the valve cover. If it fits, it's the correct one.
codymanche Posted February 12, 2013 Author Posted February 12, 2013 Thats what i was thinking. However the Cherokee donors isnt plugged in were we are talking about. I wanted to check first.
cruiser54 Posted February 12, 2013 Posted February 12, 2013 3-wire plug that only uses 2 wires. What year cherokee and what year MJ?
codymanche Posted February 13, 2013 Author Posted February 13, 2013 i have the inline 6 but thanks tho i wasnt clear about it when i posted it. still looking for the exact spot and mine is a 90.
codymanche Posted February 13, 2013 Author Posted February 13, 2013 3-wire plug that only uses 2 wires. What year cherokee and what year MJ? the donor is an 89 and the comanche is a 90
cruiser54 Posted February 13, 2013 Posted February 13, 2013 the donor is an 89 and the comanche is a 90 Should appear pretty much like the photo of the 2.5 actually.
codymanche Posted February 14, 2013 Author Posted February 14, 2013 thats what i wanna say too just a gut feeling that thats not it.
cruiser54 Posted February 14, 2013 Posted February 14, 2013 thats what i wanna say too just a gut feeling that thats not it. What do you need? The color codes of the wires in the harness?
codymanche Posted February 14, 2013 Author Posted February 14, 2013 that would work too! on the donor though where the crank sensor plugs in its plugged in goes through the fire wall and then theres one by the valve cover. the one i unplugged went through the firewall on the xj donor. the comanche only has one by the valve cover. I'm wanting to know if thats it?
cruiser54 Posted February 14, 2013 Posted February 14, 2013 Sounds like the donor had the CPS bypass done but the tech didn't cut off the original connector as outlined in the tSB.
Eagle Posted February 14, 2013 Posted February 14, 2013 Sounds like the donor had the CPS bypass done but the tech didn't cut off the original connector as outlined in the tSB. ^^^ This. The early (Renix) XJ and MJs sometimes had a problem with a weak signal from the CPS to the ECU due to the fact that the CPS fed through the wiring harness to get to the ECU. The factory released a fix that bypassed the wiring harness, using a new connector that went directly through a new hole drilled in the firewall and straight into the ECU. For an 89 or a 90, the original CPU connector wires should go into the big wiring harness. If the CPU connector has two wires that run directly through the firewall, that vehicle has had the bypass performed.
cruiser54 Posted February 14, 2013 Posted February 14, 2013 ^^^ This. The early (Renix) XJ and MJs sometimes had a problem with a weak signal from the CPS to the ECU due to the fact that the CPS fed through the wiring harness to get to the ECU. The factory released a fix that bypassed the wiring harness, using a new connector that went directly through a new hole drilled in the firewall and straight into the ECU. For an 89 or a 90, the original CPU connector wires should go into the big wiring harness. If the CPU connector has two wires that run directly through the firewall, that vehicle has had the bypass performed. Ask me how I know. I plugged a new CPS into the old plug and chased my tail for awhile. You don't forget crap like that!!
codymanche Posted February 14, 2013 Author Posted February 14, 2013 ill take a pic of it and post it i just wanna have the right plug. i don't wanna have to by pass the starter just to start my truck.
HOrnbrod Posted February 14, 2013 Posted February 14, 2013 My take on this is that AMC located the dumb memory-less Renix computer in the cab so all the multiple sensor outputs had to pass through multiple connectors to further attenuate an already weak signal to feed it. Then they came up with Kluge fixes like bypasses like the CPU "fix". It was a win-win for AMC because the average owner had no means to diagnose the ECU w/o a the proprietary DBR2 scanner, thus had to resort to dealer diagnostic $$ for troubleshooting. Or Easter egg swap sensors with more $$ until maybe or not the problem is fixed. Makes zero sense to me. :dunno:
cruiser54 Posted February 14, 2013 Posted February 14, 2013 My take on this is that AMC located the dumb memory-less Renix computer in the cab so all the multiple sensor outputs had to pass through multiple connectors to further attenuate an already weak signal to feed it. Then they came up with Kluge fixes like bypasses like the CPU "fix". It was a win-win for AMC because the average owner had no means to diagnose the ECU w/o a the proprietary DBR2 scanner, thus had to resort to dealer diagnostic $$ for troubleshooting. Or Easter egg swap sensors with more $$ until maybe or not the problem is fixed. Makes zero sense to me. :dunno: Really, it was too much influence from the 46% owners of AMC when the XJ/MJ was developed. Renault. That's where Girling clutch cylinders came into play, along with BA-10 trans, Renix, cab lights, closed cooling system etc.
codymanche Posted February 14, 2013 Author Posted February 14, 2013 well when i get to the truck again ima try but i just wanna see where someone elses pluuged in so i don't have to play find the plug!
jpnjim Posted February 16, 2013 Posted February 16, 2013 Really, it was too much influence from the 46% owners of AMC when the XJ/MJ was developed. Renault. That's where Girling clutch cylinders came into play, along with BA-10 trans, Renix, cab lights, closed cooling system etc. ^^^also had to do with the French protectionary laws that required all vehicle produced to have xx% French content. Not surprising that Renault, at the time, still partially owned by the French Government*, would apply their content laws to US vehicles produced for US consumption. (rolleyes) *The French Government claimed the deceased owner of Renault had worked with the Nazi's during the WWII German occupation of France. He wasn't alive to deny it, so they Nationalized (took) the company. French Government ownership of Renault was the reason AMC had to sell AM General, and all its lucrative US Government contracts. /History lesson off ;)
