702_MJ Posted January 21, 2013 Share Posted January 21, 2013 So I'm in the process of swapping on 97+ doors. And the door hinge is kinda worn out, not pulling from the body but the actual hole the pin goes in. Anyone know any other way to get the pins out besides a BFH and some penetrating oil? And then once I get them out, what can I put back in? I know they sell pin kits but it's for later model Cherokees. Thanks in advance Link to comment Share on other sites More sharing options...
jimoshel Posted January 21, 2013 Share Posted January 21, 2013 First soak with penetrating oil. Try to tap it out using a punch a hair smaller than the hole. This won't work because of the worn spot on the pin but try it anyway, just so you can say you tried. After giving up with that method get a drill bit a hair smaller than the pin hole.Now try drilling the pin out. After a good start the bit will jamb in the pin and jerk the drill out of your hands, giving your wrists a good whack as it spins around. Loosen the chuck and release the bit from the chuck. Say to h*ll with it and use it the way it is. Ask me how I know. Link to comment Share on other sites More sharing options...
702_MJ Posted January 21, 2013 Author Share Posted January 21, 2013 Hmm ok, well I'll keep trying. They were put in there, there's gotta be a way for them to come out. I'll let you know when I find the secret haha Link to comment Share on other sites More sharing options...
Backdraft Posted January 21, 2013 Share Posted January 21, 2013 Maybe I'm just lucky. I've always simply used a pair of channel locks and popped them out by squeezing them. Link to comment Share on other sites More sharing options...
702_MJ Posted January 21, 2013 Author Share Posted January 21, 2013 Huh? howd you squeeze them? Ive been pounding mine all day with no sign of budging...course 20+ years of crap getting in I'm sure doesnt help. I'm soaking them in penetrating oil over night, just gotta find my burnzomatic tip and a canister and I'm gonna BBQ those suckers tomorrow Link to comment Share on other sites More sharing options...
mnkyboy Posted January 21, 2013 Share Posted January 21, 2013 I cut my hinges off and replaced them with a set of XJ back door hinges. The back doors usually see far less use and are typically in very good condition. Link to comment Share on other sites More sharing options...
mjeff87 Posted January 22, 2013 Share Posted January 22, 2013 X2 on channel locks.....hold them upside down and put the bottom jaw (which really is the "top" jaw) on the bottom of the pin. Put the other jaw on the metal piece that the pin fits in and squeeze. The pin will pop up, but not the whole way out. Use needle nose to remove completely. Install is reverse of removal, sans the needle nose. Link to comment Share on other sites More sharing options...
