88swampedmj Posted March 12, 2007 Posted March 12, 2007 lastnight i took the 91 2wd up to the shop to swap the slave cylinder which is what was bad all along.. i got everything unbolted had the tranny tilted down.. undbolted the bellhousing from the motor.. but the tranny will not come out for nothing! i tried for hours to get it off the motor but it still won't budge :headpop: is there some trick to it? when i did the clutch on my 4wd tranny..(the 88 manche) .. it popped off after unbolting it from the motor.. so wtf? iam out of ideas and its just sitting up at the shop right now tranny hanging...
Rokhound Posted March 12, 2007 Posted March 12, 2007 Did you take the cross member out all the way if you check on the back of the tranny bracket there is a tab that hold the exhaust pipe up that was were mine was hung up. Same thing happen to me the 4x4 tranny fell out and the 2wd would not move so I bet it is that tab.
mjeff87 Posted March 12, 2007 Posted March 12, 2007 If you're sure you got all the bellhousing bolts off, thread one or two of them back in a bit to act as a safety and push up/down on the tailshaft while pulling it backward...the only thing that could be hanging up is the input shaft splines inside the clutch disc. Wait a minute, yours is a 4.0L right? Did you pull the starter? Jeff
88swampedmj Posted March 12, 2007 Author Posted March 12, 2007 yep i pulled the starter, and the crossmember is all the way off.. everything is off. this isnt the first time ive done a clutch.. but it is the first time ive done one on a 2wd tranny i thought it would be easier.. but its making me regret owning this truck
Rokhound Posted March 12, 2007 Posted March 12, 2007 that tab is part of tranny not the cross member i only metioned the the cross member because i did not see that tab until the cross member was out of the way i hope you find what holding it in there
Pete M Posted March 12, 2007 Posted March 12, 2007 Last time I pulled a trans I forgot a couple bolts that attach the trans to the dust shield. :roll: Oops.
88swampedmj Posted March 12, 2007 Author Posted March 12, 2007 yea i saw that tab and used it while i shook and pulled the tranny.. every bolt is out.. this thing is so ghetto riged its not even funny.. everything that ive looked into fixing so far has been so F***ed.. so iam really not suprised.. but so dissapointed its taking this long .... i went to change the taillight bulbs and someone put WOOD screws in them then tried to drill them out but couldnt so they were flat headed wood screws holdin the taillights on WTF??? its just little stuff like that haha so iam not suprised when things go wrong now
