Zebvance Posted December 26, 2012 Author Share Posted December 26, 2012 Got a update. Mechanic got to the truck this morning and said it started up and ran just fine. Told him to let it Idle until it dies. Called him back and he told me that it died after about 15 min. Said the fuel pressure is reading 35 psi when running and 40 at crank which is normal so the fuel pump is good. He told me that he confirmed that it is not getting a spark. I told him it sounds like the cps and told him how to tested it and he is not cooperating very well. Acts like he doesn't want to mess with it and is telling me sounds like the ECU is bad. So I finally got him to agree to let me have some one drop off Cruisers CPS testing document and test is that way. We will see what happens. Over all is sounds like CPS Problem to me. Link to comment Share on other sites More sharing options...
88whitemanche Posted December 26, 2012 Share Posted December 26, 2012 Not in a bad way but many mechanics don't like to be told what to do especially when your going to one in the first place but not a lot are not open to other ideas to test the truck.... Link to comment Share on other sites More sharing options...
Zebvance Posted December 27, 2012 Author Share Posted December 27, 2012 Nother update: So the mechanic did cruisers CPS test. He told me that sometimes it would read the right voltage and sometimes it wouldn't read at all. Also some time even if it reads 0 voltage it will start. He is trying to tell me that he thinks it is a computer issue and he has consulted anothe mechanic about it and he agrees. He says that the CPS is a magnet and it either works or it doesn't. So he things its not the CPS and its the computer. I then went on to ask him, if its the ecu what is the plan of action. He said he doesn't know because he doesn't touch computer. So it's still sounds like the CPS to me and I know how they can act up for The stories I have read on here. So I tracked down a dealership CPS and am having it shipped to the shop. It was like 96 bucks and its going to take 5-7 working days to get there. When I called the dealership they also asked me if I wanted the high altitude one or regular? I just said regular. Any way please tell me y'all's opinions. And CRUSIER chime in with yours too. Oh one more thing, I have a brand new oil pan, felpro oil pan gasket, and felpro rear main seal sitting here that I have been waiting on putting on. I figured if the truck was just going to be sitting there for the next week I was going to have him put on the oil pan, RMS, and oil pan gasket. Well I asked the guy he he would do it and he said he would rather not mess with it........ Guy sounds like a idiot to me.... Link to comment Share on other sites More sharing options...
mvusse Posted December 27, 2012 Share Posted December 27, 2012 Find yourself a better mechanic, preferably one who likes to fix vehicles. Link to comment Share on other sites More sharing options...
Zebvance Posted December 27, 2012 Author Share Posted December 27, 2012 Unfortunatly there is not many options to take the truck where it is at and I can't afford to get it towed around town. Link to comment Share on other sites More sharing options...
cruiser54 Posted December 27, 2012 Share Posted December 27, 2012 CPS works totally independent of anything else. It generates it's own signal. The mechanic is full of it and has no frickin' clue. Link to comment Share on other sites More sharing options...
Zebvance Posted December 28, 2012 Author Share Posted December 28, 2012 Yea he is a idiot. But ok,let's just say after I replace the CPS it's still dieing and the next plan of action is the computer. Where can I find one? What kind do I need, and how much is it going to cost me? Link to comment Share on other sites More sharing options...
cruiser54 Posted December 28, 2012 Share Posted December 28, 2012 Yea he is a idiot. But ok,let's just say after I replace the CPS it's still dieing and the next plan of action is the computer. Where can I find one? What kind do I need, and how much is it going to cost me? Used $35 at U-Pull-It. Bet that's not it though...... Link to comment Share on other sites More sharing options...
mvusse Posted December 29, 2012 Share Posted December 29, 2012 I still say running continuously rich (open loop) and flooding due to bad O2 sensor. Link to comment Share on other sites More sharing options...
cruiser54 Posted December 29, 2012 Share Posted December 29, 2012 O2 being bad can cause open loop, but that's not all that rich, especially to cause flooding. It's a predetermined program in the ECU. Half the guys on this forum with a rEnix Jeep probably have bad/lazy O2 sensors and don't know it. MAP getting low vacuum can cause lots of flooding though. Causes ov overly rich mixture in order of highest degree and severity. 1-MAP 2-CTS 3-IAT 4 O2 sensor Link to comment Share on other sites More sharing options...
mvusse Posted December 29, 2012 Share Posted December 29, 2012 A friend of mine swapped a Renix 4.0 into a YJ that originally had a carbureted 2.5. He was running without an O2 sensor, which worked ok on the highway (although about 12 mpg), but in stop and go traffic or out on the trails it would flood out and stall, And then be unable to start for 30 minutes or so. Hooked up an O2 sensor in the front exhaust pipe (got a new pipe that had a bung for one) and no more problem, no more stalling and close to 20 mpg. Tell me again how the open loop program is not that rich. Link to comment Share on other sites More sharing options...
cruiser54 Posted December 29, 2012 Share Posted December 29, 2012 Not been my experience in 25 years of working on these Jeeps. Sometimes we found dead O2 sensors only because it showed on the DRB tester that way and nobody had complained of a driveability/idling issue. But, there's always something new. Couldn't hurt for the OP to check/change his O2 sensor but I've never seen one choke out a motor on it's own. There were always other contributing factors. Also, your friends Jeep was not a stock installation and other factors could have affected it. Go unplug your O2 sensor and drive around for a while. Bet it doesn't stall. Idle may be a tad low or maybe rough...... Link to comment Share on other sites More sharing options...
Zebvance Posted December 30, 2012 Author Share Posted December 30, 2012 although I have not confirmed it, I highly doubt my o2 sensor is bad. I just did a full exhaust revamp. Pacesetter header high flow cat, magnaflow muffler and running 2.5 inch pipe, with a brand new o2 sensor. This truck runs smother than it ever did before this. I have had the truck for 1 year in feb. bought it with around 99k and it has 103k on it now. With in those 4 thousand miles I have put atlease 3-4k$ into it. Just shy of a full rebuild the engine has ran great since I have done the work on it. Link to comment Share on other sites More sharing options...
Zebvance Posted January 10, 2013 Author Share Posted January 10, 2013 UPDATE: ordered a CPS form the dealership, got it installed and runs fine now. THANKS CRUSIER! Link to comment Share on other sites More sharing options...
cruiser54 Posted January 10, 2013 Share Posted January 10, 2013 UPDATE: ordered a CPS form the dealership, got it installed and runs fine now. THANKS CRUSIER! Cool beans. Link to comment Share on other sites More sharing options...
