My '89 project MJ is about to get cranked up and I'm not sure as to the direction to take concerning the interior. It currently has the maron interior with a maroon cloth bench seat. The only thing currently amise there is a sagging head liner.
I'm not really into the maroon color but a complete dash, carpet, seat, door change is probably more than I want to do initially. If the project works out as expected, then I will probably be willing to do more later on including a 97+ door swap. I like the 97+ dash also but I'm not sure the time investment would be worth it to me. Is it possible to fit the '89 interior door units to the +97 doors?
Anyway the main question is this, how bad would it look to change interior color in steps such as how would a grey head liner look with a maroon interior? What if the visors were made grey also?
Would I be better off just doing the head liner in maroon and then recovering it again later when/if I do the rest of the interior?
What's the odds of finding some nice maroon buckets from an XJ or WJ?
My preferred stages:
1) headliner & carpet change to grey
2) add grey buckets
3) door panels / dash / other
After the decision to begin #1, start scavenging the other grey pieces required. If you can find them easily enough, then proceed. If not, you'll be okay stopping at stage 1 or 2 and selling what you've found.
IMHO.....
Why do the job twice, just start doing grey. The plastic parts you can paint grey. Its a work in progress, so it doesn't have to match till you're done with it, or it doesn't have to match at all if you like it like that.
Grey interiors are very common in JYs. Dashes, door panels, kick panels and buckets from 4 door XJs will work (will have to mod the seat brackets and 2 door XJ seats would be better). The A pillar trim may work. B pillar trim is MJ specific as is the back window trim. Those parts can be painted if you can't find grey replacements. The carpet can be dyed/painted as can the carpeted panel behind the seats, probably black to cover the maroon if dyed.
So, I would go with the grey headliner and visors if that's the color interior you want to wind up with.
